6 | |
6 | |
3 | |
2 | |
2 |
Just as for Clusters, I would like to be able to change a Map constant on the Block Diagram to be viewable as an Icon when it has been made a TypeDef. You can't directly edit the constant data, so for me it doesn't make it worth the large amount of real estate that it can take up, especially if you have a Map of Maps/Sets.
So for example, instead of this:
I would like:
