13 | |
11 | |
3 | |
3 | |
3 |
How many times have you found yourself entering items in an array, typing merrily along, only to have to switch back to a mouse to click on the next element and type it it. I suggest that Alt-Enter complete the current entry and move to the next array element.
This idea proposed using the Tab key, which collides with manual tool changes. Shift-Enter was also proposed, but it collides with the ability to move to a new line in strings and to add another element to a enum/ring.
I propose using Alt-Enter to advance to the next array element:
Available in LabVIEW 2020 SP1 and later. You can press 'Tab' and 'Shift-Tab' to navigate forward and backwards in an array constant or control. Note that this functionality requires that you have Tools > Options > Environment > General > Lock automatic tool selection CHECKED.
