11 | |
7 | |
3 | |
2 | |
2 |
Most of the time, I put remote devices on our internal network. If I set up the device so the IP Address is dynamically assigned, the IP often changes. But, the project needs me to point to a device via specific IP address. If the IP Address changes, I constantly have to update the remote devices properties in my project, often times not realizing this is even an issue until a deployment fails because the device can't be found.
I'm proposing an idea to link to a devices' alias (or some unique ID other than IP) and allow the project to automagically update the IP Address.
You can type in the device's name in the IP Address / DNS Name field.
