13 | |
11 | |
3 | |
3 | |
2 |
Format into text is very useful but can become hard to edit when it has a lot of inputs. I propose, instead of one huge format string, that the programmer be allowed to put the required format next to the corresponding input. Also, the user should be allowed to enter constant strings, e.g.. \n, \t, or "Comment", and have the corresponding input field automatically grayed out.
