6 | |
2 | |
2 | |
2 | |
1 |
In most of the applications we need to first create a queue and the enqueue the first element, which is currently a two step process. Just like create if not found? if there would have been an additional terminal which can enqueue the element to the queue, the two step process can be cominbed into a single step.
