| User | Kudos |
| 13 | |
| 10 | |
| 7 | |
| 5 | |
| 5 |
Reset the Probe index when the <Probe Watch Window" is closed
above, the probe index equal 18, however only one probe is active.
When you close the <Probe Watch Window> ...therefore when you close all probes,
in this case, reset the probe index for the next time.
It's useless and annoying to have a probe index equal to 18 (sometimes much more),
when only one probe is active. Thank you.
