7 | |
6 | |
2 | |
2 | |
2 |
We can specify custom markers for axes, but even if we do so, there will be two additional markers that cannot be hidden: the Min and Max!
I would prefer an option to get rid of these two extra markers. Often they are distracting and not desirable for a clean look. For example we might want the x-axis to start at zero, but we want some padding to the left so data points (e.g. small circles) are not cut off by the other axis. Here we might want the x-axis min to be e.g. -0.02, but we still want the first maker to be at zero with no markers to the left of it.
If I specify custom markers, these are the ones I want, nothing else. 😉
