In the application builder we can define Pre / Post Build actions.
The template VIs fro Pre and Post build actions are located in :
~\LabVIEW 2018\resource\Framework\Providers\Builds\Common\Pre and Post Build
Of course these can be modified at our own risks.
From the application builder, LabVIEW offers to generate Pre / Post build VIs with the specific connector pane, when generating such a VI, LabVIEW **simply** creates copy of the templates, the base VIs being "Pre Build Action.vi" and "Post Build Action.vi")
Instead of asking where to save a copy of a fix file, I wish LabVIEW first ask which VI to use as a starting base.
Display a pop-up* listing all the possible template for pre / post build action that I placed in the folder cited above, and then use the selected one as a base for my new pre / post build VI.
* = similar to the one we get when disabling the default icon
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
