It makes no sense (from a Software Engineering and Process standpoint) to force (and store) an absolute path for a build destination directory, in the project. What if a group is sharing a project but each developer prefers to have their files located in a different folder?!!
I recommend NI consider replacing the line of code in LabView that is checking for the presence of an absolute path for the build folder with on that does: "If user entered an absolute path, use it; otherwise, prepend the current project location to whatever (relative) path the user entered before building."
