The "Array Size" Function returns an ARRAY of all dimensions (even for a 1-dim array!). Very, very often, I'm interested only to know ONE of the dimensions. I normally do "Array size" - "array to cluster" (with the cluster set to the number of dimensions) - "unbundle cluster" => wich is very clumsy.
Why not make the "Array size" customisable, e.g. with a double click like the "array to cluster" to indicate which dimension I want to know. If "all" is choosen, an array is returned as today. If "2" is choosen, the 3rd dimension is returned just as an integer value ...
would be great!
gilles
