13 | |
11 | |
3 | |
3 | |
3 |
Quite often I find myself using a combination of Array Size + Index Array with a constant to know just one size of a multidimensional array. Wouldn't it be easier, if Array size would behave in a similar way as other array functions - depending on how many dimensions the array has, so many outputs show up. The example shows 2 dimensions, but could be expanded to more
