| User | Kudos |
| 11 | |
| 10 | |
| 9 | |
| 5 | |
| 4 |
When working with Arrays via VI Server (similar to a previous idea) it's challenging to get at a single element of the array.
My workaround involves setting only one array cell visible and then changing the index to move to different elements....
Why can't we read / write the current active index of the array via Property node?
Shane.
Any idea that has received less than 10 kudos within 10 years after posting will be automatically declined.
