| User | Kudos |
| 17 | |
| 6 | |
| 5 | |
| 4 | |
| 2 |
In large &/or dense &/or multi-dimensional arrays, it'd be helpful to be able to tell the location of elements without having to either manually count or use the index values to relate to an element's location. A default tip strip could work - see image below:
