| User | Kudos |
| 2 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
When developing a utility to traverse any control using VI Server and save its contents to a file (similar to the OpenG utility using Variant) it is quite challenging to find out the size of the array's data.
There are various workarounds, but all of these are relatively tedious and over-complicated.
Why don't we have a "array data size" read only value on the property node of an array?
This would make things MUCH easier.
Shane.
