6 | |
6 | |
3 | |
2 | |
2 |
Hello!
What I really would like to se implemented as a future feature is a 'Search 1D Array.vi' with the option to do a case insensitive search.
Usually I just plug a "to upper case" vi on both array and search string inputs. It would be nice to be able to select it right on the vi instead.
The functionality should work as with the case insensitive match in the case structure.
Cheers!
//Beckman
