Hello!
I often find myself not using array of clusters in my applications since its to much hazzle to wrap up the data in forloops and then use it. Instead I put my data in straight arrays.
If a feature like "unbundle array" would be implemented as a feature this problem would be solved and the code would even look elegant.
Cheers!
//Beckman
