jacemdom
Assert structural type match with growable y inputs behaving as an or logic gate
Status: Already Implemented
See idea discussion thread for a viable workaround for the original use case.
Would allow to reduce the complexity and number of frames needed in a type specialization structure when the action is basically the same.
For example in the attached vim, the number [2] frame could be used for all number types and thus eliminate all the following frames.
13 Comments
AristosQueue (NI)
NI Employee (retired)
We are these days trying to build the minimum number of nodes into LabVIEW to achieve any given functionality and leaving any build-up functionality to G code. Now that we have VIMs, that's a more viable strategy than it was two releases ago. Unless the time savings is enormous and covers a wide range of users, we're preferring bulkier G code over bulkier C++ code. The latter is easier for everyone to debug, modify, etc. And if it only needs to be written once and the results are just as performant at run time then a bit of bulk seems a fair price to pay.
You'll see that in particular in the LV 2019 release (assuming all goes as planned) -- there's a wide range of obvious operations for a particular new feature that won't be in the palettes at first because we're mostly only releasing the foundation nodes and will release higher-level functionality later, building out of G -- though I try to never promise future functionality. 😉
jacemdom
Active Participant
Thanks for the insight into NI's strategy.
When is the 2019 beta starting?
Darren
Proven Zealot
Status changed to: Already Implemented
