6 | |
5 | |
3 | |
2 | |
2 |
One of the more important and useful functions, especially for exploratory data analysis in R, is the ability to take N samples from an input provided set with or without replacement.
LabVIEW should have that. It would be relatively straightforward, and would start moving G toward having more shared Venn-diagram with R.
https://www.rdocumentation.org/packages/base/versions/3.5.1/topics/sample
Personally, I think you should look at the NIST EDA techniques library, and built a toolset off of it. https://www.itl.nist.gov/div898/handbook/eda/section3/eda3.htm
It is tax-funded source code, so it is something you should be able to access and integrate without too much work.
