6 | |
6 | |
3 | |
2 | |
2 |
Sometime, I have to make an numeric array constant for 10 elements, for example, and each element is the 2 increment of the previous element. It will be nice if I can key in the first value in the arary, right click on it, and select "repeat series". When I do that, it should give me a panel that ask for how many row and what type of increment is needed. The type of increment should include all basic math such as add, subtract, etc. This concept is very similiar to excel.
I guess I can code some stuff that will do that, but I thought it will be a convenient feature.
Yik
