6 | |
6 | |
3 | |
2 | |
2 |
I sometimes feel difficult to see the value of a wire while editing the VI. When "Retain Wire Values" is turned ON, I need to put a probe on that wire to see last executed value. Applying probe on every other wire while coding will result in lot of probes and also it will increase the coding time.
Having a way to view the wire value on Mouse Hover in edit time will be really useful. What I feel is, the value can be displayed as a tooltip or a dialog box similar to context help window which will disappear when mouse pointer is removed from the wire. 🙂
