Background:
So building off of this (Very-simple-improvement-on-Block-diagram-clean-up-OPTIONS)
I am making VI's like this:
They have many single frames floating around, some nested. Nearly none are sequential. Inside each frame is a complete "logical unit".
Observation:
I find that when I make my whole code like this, candidates for being converted to Sub-VI are obvious. They have more wires going in, more stuff going on, nesting, and it is all in the same box.
A good example of what they look like when done is this (thanks X.):
Often I don't know what the "done" version looks like until I work through the bugs, requirements, refinements, and unhappy-paths of the "rough" version.
Suggestion:
- I think that I should be able to make a mostly hairy mess, but with the key point that inside each frame is a chunk of code that humans need to see all at once to understand how it works - AND THEN - LabVIEW should be able to look at the overall layout and pick which boxes make the best sub-VI's. I'm thinking boxes where marginal cyclomatic complexity makes big jumps might be a good starting criterion. [Cyclomatic complexity (link), Essential complexity (link)] - Let me ask you this: "Is there a variation on cyclomatic complexity that has meaning only in a visual programming language FOR WHICH FRAME ARE SUPPLIED THAT DEFINE BOUNDARIES OF COMPREHENSIBILITY (as shown above)?" I could see this like a variation on the comment section of slashdot - where there are sliders that show level settings for abbreviated or hidden, except operating on complexity and allowing transformation of the full project.
- If think that if there are 20 wires coming out of one Sub-VI and going into another - that the automatic process should bind them into a big cable (cluster, array, whatever) that is most efficient. This way my sub-VI only needs one i/o wire to communicate with its buddy and not 200. I think that a new control i/o "pin" should be used only when 1) it is specified by the user as a unique I/O or 2) when it routes to a different sub-VI. In cyclomatic complexity they talk about only one entry
