This idea specifically needed for instrument driver vis and may not for the common subvis.
So for every subvi in the instrument driver vis (say tektronix oscilloscope driver vis), we need to manually create the constants/controls and indicators everytime and instead if automatically when dropping the subvi from the palette, if all are created with some default values (off course with "View as icon" unchecked so that BD will be neat and readable) will save a lot of development time. Please comment.
Mathan
