13 | |
11 | |
3 | |
3 | |
3 |
I am not sure whether this is a repeated post or not.
However i would like to see the 'Tunnel wiring wizard" as a part of the upcoming LV version so that i can wire mutiple cases of my state machine in a single go instaed of wiring in each frame.
Here is the Tunnel wiring wizard attached
