Populating values to the "enum" control is not possible by using the "strings" property node and hence to populate a large data to a "enum" one has to create a "Ring" control use the "strings" property and replace that "ring" with the enum (or if you have enough time enter them manually) .
So why not use the "Strings" property of "Enum" to write values to it directly..See the image attached
