8 | |
5 | |
4 | |
3 | |
3 |
We update software often. Sometimes we need to know which version and build a customer is using.
My executable should be able to fetch that number when it starts up and add it to the Help/About... menu item or display it at the top of the Panel.
When building a LabVIEW executable, the build system knows that version/build number.
Let it format those numbers into a string and write it out to a dedicated textfile or add it to the .INI file.
Then when my executable runs, it can fetch and expose that number as needed.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
