RyanWright
Autosizing of new cluster controls should default to "Arrange Vertically" instead of None".
When you place a new cluster control on a VI front panel, the default autosizing option is "None".  A much better behavior would be for the default autosizing option to be "Arrange Vertically".  This would be extremely useful and would speed development of custom types in LabVIEW using cluster-based type definitions.
12 Comments
Knight of NI
@Ryan Wright wrote:
I submitted the feature request even though it was made in the past because the original request was made clear back in 2009 and I wanted this to get visibility again instead of getting lost amongst all of the posts.
I think the idea of having a LabVIEW option that would allow you to set the default autosizing option for clusters is an excellent solution.
Actually, what will happen is that this idea will simply be marked as "duplicate", and probably forgotten (the exact opposite of what you intended to accomplish). It also has the side-effect of splintering the discussion. The best thing to do is to Kudo the original idea.
JordanG
NI Employee (retired)
