6 | |
6 | |
3 | |
2 | |
2 |
If the example finder is open and an example vi is closed the LV main window appears.
That is a little bit disturbing when searching in the example section.
It would be nice if it could be kept in the background.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
