W.Muhammad
Being able to clear the history of Import Shared Library Wizard
Status: Declined
It would be very nice to have the option of clearing the history of Import shared library wizard.
When you keep importing the edited version of a library,you always have previous version of the same library with same name.
Thus, you have to set the new name for the same edited library. There should be an option of clearing the history of shared library wizard.
2 Comments
APx
If you look in <UserDocuments>\LabVIEW Data\Shared Library\ you will find .xml files corresponding to the libraries you have imported using the Import Shared Library Wizard. I discovered that deleting these files (or moving them to a different folder) clears their history entries in the wizard.
Darren
Proven Zealot
Status changed to: Declined
