7 | |
2 | |
1 | |
1 | |
1 |
Currently, when the VI is being created the controls and indicators placed on the block diagram look messy/unordered on the Front Panel (FP). Example below:
Wouldn't be better if LV simply do the basic aligment for the users?
1. Inputs on the left hand side
2. Outputs on the right hand side
3. Error controls always on the bottom
4. Vertical order of the controls and indicators by order of apperance in block diagram
Example of the result:
