This is a suggestion a bit technical and is posted here following the suggestion of the National Instruments support center.
When building a shared library from a vi, the run time engine make use of a configuration file which has the following name: <name of the executable program which links in the DLL>.ini .
The fact that the name of this file is not configurable by the users is EXTREMELY annoying in my application (the LV DLL is a plug-in of third party software) because causes the corruption of the calling program configuration file.
It seems very easy to me solving this problem by making user-selectable the name of the ini file used by the DLL produced by LV. It also would improve the interoperability of LV with third party software.
I really hope to see this upgrade already in the next release of the software.
Thank you very much.
