JÞB
Block Diagram Cleanup should replace any Stacked Sequence Structure
Status: Declined
As a Product Owner for LabVIEW, I would not approve using block diagram cleanup for this type of refactoring operation, so I'm declining this idea.
we correctly recommended that the SSS be removed from the Structures Palette.   Let's go one step further.   Default Block Diagram Cleanup to apply the existing "Replace SSS with FSS."
11 Comments
Christina_R
Active Participant
Status changed to: Declined
Christina Rogers
