8 | |
6 | |
4 | |
3 | |
2 |
we correctly recommended that the SSS be removed from the Structures Palette. Let's go one step further. Default Block Diagram Cleanup to apply the existing "Replace SSS with FSS."
As a Product Owner for LabVIEW, I would not approve using block diagram cleanup for this type of refactoring operation, so I'm declining this idea.
