TomBrass
Bold text in a VI description by using CTRL-B
Status: Declined
It would be nice to be able to add the bold tags to the text in the VI description dialog by selecting CTRL-B. If you don't have anything highlighted, it would simply add the <B></B> to where you have the cursor, and put the cursor in between so that you can immediately starting typing the text you want bolded. If you have highlighted text, then the <B> and </B> get added around the text so that it will show up bold.
Another alternative would be if the text simply is bolded, then you would get WYSIWYG in the VI description dialog, instead of having to mess with the HTML tags. Other text formatters could be added in a similar fashion.
Tom Brass
Certified LabVIEW Architect
Choose Movement Consulting, Inc.
www.choose-mc.com
2 Comments
JÞB
Knight of NI
Not a bad Idea Tom  But why stop at bold only.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/VI-documentation-Upgrade/idi-p/1075843#comments
And why is the comment editor broke?
Darren
Proven Zealot
Status changed to: Declined
