| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
The new LabVIEW bookmark manager in 2013 is nice but one thing it does not do is scan for bookmarks, inside the dependencies of an open project. I understand that NI wants to make the loading of bookmarks quick so they likely limited it to not include the dependencies to make the loading faster because it has fewer VIs to scan. But some times a project will have a majority of the code under the dependencies section.
I think it would be nice if there were an option to load bookmarks under dependencies, but not vi.lib, and user.lib to help keep the number of VIs to scan to a minimum.
Because of the awesome API support for multiple bookmark managers, I have made a new bookmark manager that does as I describe posted here.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
