11 | |
8 | |
3 | |
3 | |
2 |
I just found out about LabVIEW NXG's C Node. I know my team would love to have it in LabVIEW to use for bit masking in a familiar syntax. The Expression and MathScripts nodes have issue with 64-bit values and give unexpected results. A quick test in C Node does fix these issues.
