CL_eisenwr
Bring NXG C Node to LabVIEW
Status: New
I just found out about LabVIEW NXG's C Node. I know my team would love to have it in LabVIEW to use for bit masking in a familiar syntax. The Expression and MathScripts nodes have issue with 64-bit values and give unexpected results. A quick test in C Node does fix these issues.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
2 Comments
crossrulz
Knight of NI
As far as bit masking, what is difficult about the AND, OR, and Logical Shift?
CL_eisenwr
Active Participant
U64s did not work properly for values values > 2^31 for the expression node. There seems to be some incorrect casting/assumptions of U32/I32. It would be nice to have this done more inline with the familiar syntax.
Example 1Example 1Example 2Example 2Example 1 ResultExample 1 ResultExample 2 ResultExample 2 Result
Bill Eisenhower
