The latest release of the Vision toolkit (Vision 2012 SP1) provides some much needed improvements to the AVI functions.
But at the same time, it introduced a new issue:
"The Quality input in the IMAQ AVI2 Create VI is only implemented for Windows
codecs. The Quality input is not implemented for codecs installed with the
Vision Development Module."
This is very unfortunate, because it worked fine in the previous release (see here)! This means you may want to reconsider upgrading to SP1!
My idea: Fix this! Re-allow the use of the quality parameter in the AVI functions so we can better compress our video!
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
