8 | |
6 | |
5 | |
4 | |
3 |
Attached is a VI which is broken in a built executable but runs in development node.
Please let the development system also show a broken VI or let the Runtime Engine accept this VI.
The problem is that the VI has subroutine priority and contains a static reference to a VI with another priority.
To reproduce include the VI in a build. (The VI can even be the only startup VI). Building passes but the executable reports an error after starting.
Tested LabVIEW Versions: 8.6, 2010 SP1, 2011
