I am currently working on a quite large project, addressing different customers / users. Therefore I have in this project several specifications for executables and for isntallers. The point is, I would like to be able to right-click an installer build specification, choose build, and every executable used in the installer specification is built as well. Today, I have to remind and select all required executable specifications, and build them prior to installer building.
