Hi !
I haven't seen a post in this section about the colors of a cluster.
I think it could be usefull to allow people to make custom colors and custom wires for their cluster, as it is possible with a lvclass.
Here is an example of the actual clusters : you got a pink wire if you cluster contains chars, but you gor the same color if there is only boolean commands or constants. that is not logical.
Could it be possible to do the same asan lvclass ?
In the porperty window of a lvclass we can modify the color and the shape of the wire, which is very usefull to quickly find the one we are looking for.
Here is a screenshot with this window :
sorry for the french LabVIEW ! ![]()
Thanks for considering this idea,
Regards
Vincent.O
National Instruments France
Été de LabVIEW 2014
12 présentations en ligne, du 30 juin au 18 juillet
