3 | |
3 | |
2 | |
2 | |
1 |
Anchore position of Bundle & Unbundle Ny Name elements to "Input cluster" and not to same point in the middle of element.
I don't like when I place (Un)Bundle By Name element to Block Diagram and when I connect Input cluster to same cluster wire then element dance on block diagram.
Similar: when you change (Un)Bundle By Name element by clicking a name terminal and selecting a name from the shortcut menu then element is dancing (moving) on block diagram.
Every time I have to shift (Un)Bundle By Name on block diagram to original position.
Expected behavior: Anchor (Un)Bundle By Name position to Input cluster part of element.
Second Unbundle By Name is reference of original position.
Second Bundle By Name is reference of original position.
