5 | |
4 | |
3 | |
3 | |
3 |
Rewrite the CAN Frame API library by using the 4x2x2x4 connector pattern for each VI.
Currently, the 13 (thirteen !!!) patterns (4x2x2x4, 4x2x2, 4x1x2x4, 4x1x1, 4x3, 4x2, 3x1x2, 3x4, 3x3, 3x2, 2x4, 2x3 and 2x2) lead to wire bends and make the alignement of the VIs more difficult.
Available in NI-XNET
