| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
As a LabVIEW user, I would like to see who has called the current VIs when a breakpoint is placed on it.
From the stack view, when a vi is double clicked, the corresponding vi block diagram should open highlighting the block diagram area from where the call is made to the next vi.
If posssible the stack view can show the inputs and outputs of all the VIs in the stack view.
An example screen is provided as an attachment.
