6 | |
5 | |
2 | |
2 | |
2 |
DAQmx allows you to change between active and open collector modes per line on cards that only support per port changes. It is suggested that LabVIEW or DAQmx give a warning when trying to do this to tell you that the device only supports per port changes.
Thanks!
Kira T
