| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
I should be able to modify a class with no private data to be an interface and vice versa. This post indicates it's not readily possible currently. But, the documentation for interfaces is sprinkled with statements that they should be for the most part interchangeable with classes.
