13 | |
11 | |
3 | |
3 | |
3 |
When using LabVIEW in combination with other languages, it would be really nice for LabVIEW to be able to read from and write to the stdout and stderr streams. For example, when writing a dll in C that is to be used by LabVIEW, it would be really nice to be able to see the output and error streams from within LabVIEW. As it stands you have to jump through hoops in another IDE or create a log file or some other workaround if you want to see what might have happened inside the dll to cause it to crash.
