11 | |
10 | |
3 | |
3 | |
2 |
In a simple project, the main entry point into an application is usually easy to find:
However, for more complex projects (particularly those utilising libraries/classes) it may not be obvious where to begin:
Proposal:
LabVIEW should provide a mechanism for tagging one or more VIs such that they are easily accessible to someone unfamiliar with the project.
One possible implementation:
