Let's change the front panel default color from the traditional darker grey/gray to a lighter and more modern color - see picture B (the lighter grey/gray is the same used in LabVIEW dialogs). This modification would only affect new VIs.
In addition, we should modify the default controls to lighter colors and change the graphics background color from black to white - see picture C.
A) Default Colors B) Lighter grey default
C) Lighter controls and white graphic background
