Many of you know that the things called variables in LabVIEW are not variables at all. This regularly causes some confusion. Ben elegantly explains this here where he suggests that a local variable in LabVIEW is more like an I/O device.
I propose that they be called something like I/O device, I/O register or I/O buffer. Maybe "Control Buffer". The idea is not to call variables something in the list but to simply come up with a better name.
I understand that there is a lot already written about LabVIEW that refers to those things as variables and that much documentation would have to change. But I think that LabVIEW documentation should at least start to call "variables" something different.
At a minimum this should be clarified in the documentation on variables.
