Andi_S
VI conversion WebService
Status: New
Just 5 min ago I was in the situation that I downloaded an example VI from an NI support forum. I double clicked it and I got the message that the LabView-Version that was used for storing the VI is newer that my LabView version 😞
Most likely the VI could run without problems on my old Version (LV2009).
What I suggest to get around this kind of problems are two things:
1) create a web-based service (maybe only for registered users) where users can upload single VIs or ZIP-Files with a complete program structure. The VIs should be converted to the selected LabView version and send back to the user together with a conversion report.
2) integrate this service into LabView: If the user tries to open a VI that was stored in a newer LV version, LV should connect (after user confirmation) to the NI-Server for automated VI conversion.
3 Comments
crossrulz
Knight of NI
For now, there's the Version Conversion Board.  And I'm pretty sure this has been suggested before, I'm just too lazy to perform a search right now.
Knight of NI
I would like to see those Idea be taken by NI's service team to look up all of their AppNotes/WhitePapers/whatever to supply an updated version of any old example code on their website!
It shouldn't be so hard to scan their server and it should be no problem at all for NI to supply a LV2009 version of any older VI...
TomOrr0W
Strongly Related Idea (not sure if it should count as a duplicate, as that version doesn't mention web service):
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/A-separate-utility-software-for-Upconverting-and-Down...
